computersteve
May 10, 2020Apprentice
Ring Live Stream Doesn't Work With Orbi
I have tried everything to get the Orbi to work correctly with Ring doorbell live stream. I tried the latest firmware / downgrading / installing the custom firmware from Voxel. I then tried everthing...
CrimpOn
May 10, 2020Guru - Experienced User
I noticed that it has been several hours and no one has posted a response. Perhaps a "silly question", but does the Ring doorbell function correctly with the Ring app? And, this is a "powered" Ring device, correct? (not battery)
- computersteveMay 10, 2020ApprenticeYes. It works fine only the Orbi doesn’t work correctly with it. If I use my isps WiFi it works but I disabled that cause I really only wanted to use my Orbi in AP mode.
- CrimpOnMay 10, 2020Guru - Experienced UserSorry I wasn't clear. Ring has an "app", correct? And in addition to the Echo, the camera app also fails?
- computersteveMay 10, 2020ApprenticeYes both fail. Then sometimes both work. The issue with the Orbi is it’s very inconsistent with live view. Sometimes it loads. Sometimes it doesn’t.
