computersteve
May 10, 2020Apprentice
Ring Live Stream Doesn't Work With Orbi
I have tried everything to get the Orbi to work correctly with Ring doorbell live stream. I tried the latest firmware / downgrading / installing the custom firmware from Voxel. I then tried everthing...
computersteve
May 13, 2020Apprentice
Well then you must be an anomily.. I have verified that connecting to either the ring doorbell pro chime extender or my ISPs wifi results in a near instant live view.. While connecting to the orbi results in a spinning circle with eventual timeout. Something isn't working correctly with the Orbi & ring. This has been complained about numorous times (Ring Orbi Issues) with no fix from netgear. At this point I don't recommend you using a Ring Device with the Orbi. I wonder if the new Ring Doorbell 3 fixes this problem since its dualband. Still I don't think its right to have to replace 3 doorbells because of faulty networking equipment.
Topspin14m
May 13, 2020Guide
I think if no Ring worked with Orbi, you’d see far more posts on this (don’t you think)? The issue is going to be the distance from the Orbi to your Ring and what is in between. You are connecting to three different devices. Are they all located in the same place? If not, your test isn’t valid. If so, you have to consider whether they are interfering with the Orbi. In any event, it’s not all created equal. If you want the Orbi to work with the Ring, I’d move it closer to the Ring.
- computersteveMay 21, 2020Apprentice
I now know its 100% the orbi. The ring extender pro works perfect. I also tried just hooking up an apple airport extreme and setting that as a dedicated access point for the Ring Door bells. They now also work that way. Everytime I switch to the Orbi network its a constant spinning circle or the stream doesn't load. Tried factory defaulting, tried Voxel, Tried disabling MMU or renabling / turning on and off fast roaming, beoforming etc.. Tried all these combinations, & it still isn't reliable. Please netgear fix this in the firmware. The orbi isn't handling Ring products correctly.
- FURRYe38May 21, 2020Guru - Experienced User
Have you tried v16 FW?
Please open a support ticket and let NG know if your having problems.
- CrimpOnMay 21, 2020Guru - Experienced User
Almost glad my doorbell is positioned where a Ring makes no sense, so I have been spared this misery. For these tests, the airport extreme and the Ring extender pro were located where the Orbi unit is located, correct?
Correct. They are right next to each other.
I was on the latest firmware 2.5.1.16. I also tried Voxel V9.2.5.1.17SF-HW. It doesn't work correctly with a Ring Doorbell Gen 1. It just doesn't & I can't recommend this product for that reason. The point of the product is better wifi everywhere. This is not the case.
