computersteve
May 10, 2020Apprentice
Ring Live Stream Doesn't Work With Orbi
I have tried everything to get the Orbi to work correctly with Ring doorbell live stream. I tried the latest firmware / downgrading / installing the custom firmware from Voxel. I then tried everthing...
computersteve
May 23, 2020Apprentice
The ring pro is a dual band ring product. This might be why you aren’t seeing a problem. My ring devices are gen 1 only 2.4ghz.
Bing-Stroller
May 24, 2020Luminary
OK, I now appreciate the lack of dual band.
Do the gen 1 report RSSI ?
Any joy with Rapid Ring ?
- computersteveMay 24, 2020Apprentice
As I said.. I tried all things, Even moving the satellites right next to the rings.. The reliability is random. Sometimes it works, most of the time it just spins till it times out. I am now using Apple Time Capsules (Airport Extremes basically) that I have two separate networks.. 1 specifically for Ring devices / my orbi network. Doing this the live stream loads practically instantly. Also its something to note that the RSSI is actually worse doing this but the stream loads, meanwhile on the RSSI for the Orbi network it was always excellent but the stream most of the time didn't load.
