computersteve
May 10, 2020Apprentice
Ring Live Stream Doesn't Work With Orbi
I have tried everything to get the Orbi to work correctly with Ring doorbell live stream. I tried the latest firmware / downgrading / installing the custom firmware from Voxel. I then tried everthing...
computersteve
Jun 29, 2020Apprentice
The only thing that worked for me was to not use the orbi & setup a router in AP mode / connect the ring devices to that. They load instantly & I don't have to disable a motion zone. I'm glad that helped you. I hope that eventually Netgear fixes this problem.
Mstrbig
Sep 06, 2020Master
computersteve wrote:The only thing that worked for me was to not use the orbi & setup a router in AP mode / connect the ring devices to that. They load instantly & I don't have to disable a motion zone. I'm glad that helped you. I hope that eventually Netgear fixes this problem.
That pretty much tells me your Ring still has the IP address assigned to it from the other router. You may have to reset the ring and re-configure it to grab an IP address from the Orbi DHCP server.
- computersteveSep 06, 2020Apprentice
No, its sparadic.. It works sometimes on Orbi & always on my accesspoint. IDK netgear is never gonna fix this problem. Just google Ring & Orbi.. Tons of problems.
