kkelso22
Dec 26, 2024Follower
RMR50 connecting to Ring Camera
I have several Ring products connected to my home wifi network, which is a mesh Orbi RBR50. For some reason I cannot connect just one spotlight camera to the network. I explained the issue to Ring an...
Dec 26, 2024Guru - Experienced User
Try this. Turn OFF all RBS. Then turn the power output of the 5Ghz radio to 25% on the RBR. Be sure that 20/40 MHz Coexistence enabled. Under Advanced Tab/Advanced Settings/Wireless Settings. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
