gholson2
Jul 03, 2018Initiate
Robot Vaccums and Orbi mesh network
Well this is getting quite a bit frustrating.
Should be an easy question. I purchased a deebot robot wifi enabled vac and the unit will not connect to the wifi please dont tell me this is beca...
Jul 04, 2018Guru - Experienced User
One test you can do. Disable all WPA securiity temporarily on the Orbi system. Then try to connect any of the vaccuums to the Orbi to see if they connect at all. Then turn on WPA and TPIK ON the router and test the vaccuums again. Do they connect at any time?
