gholson2
Jul 03, 2018Initiate
Robot Vaccums and Orbi mesh network
Well this is getting quite a bit frustrating.
Should be an easy question. I purchased a deebot robot wifi enabled vac and the unit will not connect to the wifi please dont tell me this is beca...
Jul 04, 2018Guru - Experienced User
One test you can do. Disable all WPA securiity temporarily on the Orbi system. Then try to connect any of the vaccuums to the Orbi to see if they connect at all. Then turn on WPA and TPIK ON the router and test the vaccuums again. Do they connect at any time?
gholson2
Jul 04, 2018Initiate
Well not sure how this worked but it wouldnt work without the password until i took the steps suggested by Furrye38 thanks for the help. Connected right away without password after I set up manually. But wouldnt allow me to add a password back. I added the password back and reset up the robot and boom connected. thanks for all the help!
- FURRYe38Jul 04, 2018Guru - Experienced User
Enjoy. :smileywink:
- speckmasterJul 05, 2022Aspirant
Not sure if you're still around. I'm having the same problems you had. I think I did what you were told to do, but I didn't have much luck. When I disable the password, the robot connects right away...like you said. When I turn on the password, it stays connected for a few minutes, but then loses it. Any suggestions?
thanks
