gholson2
Jul 03, 2018Initiate
Robot Vaccums and Orbi mesh network
Well this is getting quite a bit frustrating.
Should be an easy question. I purchased a deebot robot wifi enabled vac and the unit will not connect to the wifi please dont tell me this is beca...
gholson2
Jul 04, 2018Initiate
Well not sure how this worked but it wouldnt work without the password until i took the steps suggested by Furrye38 thanks for the help. Connected right away without password after I set up manually. But wouldnt allow me to add a password back. I added the password back and reset up the robot and boom connected. thanks for all the help!
Jul 04, 2018Guru - Experienced User
Enjoy. :smileywink:
