pstoric83
Jan 27, 2018Guide
Roku connecting at 2.4G instead of 5G
Hey guys. So far my Orbi has been working flawlessly since July but I had a question. I see my Roku Ultra connects to the 2.4G freq yes it's in the basement directly underneath the Orbi Satellite. I ...
budy
Jan 27, 2018Luminary
The Orbi is probably "pushing" the Roku to the 2.4GHz due to the fact that the 2.4GHz signal is much stronger. You could only work around that, by having a different SSID for the 2.4 and the 5.0GHz bands. There is a threat in this forum, that describes how to do that. On the other hand, if the Roku does fine on the 2.4GHz band - and why shoudln't it?, you might just want to leave that alone and rely on the Orbis to figure out, how the clients connect best to its networks.
- hccs2000Apr 24, 2018Aspirant
I have a Roku 3 purchased in 2012, and 2 brand new Roku Express. None of them show the 5G SSID when I perform the scan from Roku Setup. I tried putting in the info in hidden network in Roku setup and it still would not show the option. I want to dump DirecTV and go with streaming, but I rarely get over 26M DL speed without Roku on the 2.4G SSID. I am between 80M and 112M on 5G, which what I would prefer to connect to... Is there a way to get the Nighthawk to run 802.11n? Am I stuck with the channels offered in the Netgear Configurator?
Any suggestions on how to get Roku to run on the Netgear 5G would very much appreciated!
- tsigApr 25, 2018Luminary
All of my Roku's connect to the 5g band, so no help to you there, but are you experiencing any issues on the 2.4 band?
- hccs2000Apr 25, 2018Aspirant
Single Roku no problem... Concerned that running 3 simultaneously will be an issue... Speed testing of the 2.4G line was all over the place at different times of the day. Warned by Roku that speed was too slow during configuration when trying to connect to 5G and reverting back to 2.4G... I will test farther this weekend.
- 4tuneduckJul 11, 2018Aspirant
Roku express only works with 2.4, and it will not work with 5.0.
Recently upgraded my R6700v2 firmware with smart connect.
By enabling the smart connect feature, my Roku express will not connect to the router anymore. So that feature is useless. Have disabled it already.
Please let me know if this help and if you can add something to it. Thank you.
