hm69
Aug 18, 2021Aspirant
ROKU connects to WIFI but not internet on RBR50 + RBS40V satellite
RBR50 Firmware V2.7.3.22 RBS40V Firmware V2.6.2.4 I had a ROKU express which was working fine until a couple of days ago. I noticed my kids watching TV when they were not supposed to and decid...
hm69
Aug 20, 2021Aspirant
Now, I am 100% sure the cause of the problem is the Orbi router / sattelite.
I switched out the Orbi and connectected my old D-Link router I had before the Orbi, and the Roku works.
I suspect the issue is caused by the recenr firmware update on the RBR50 (2.7.3.22). Just dont know what.
Is there no one at Netgear who can assist? I can pay for support (which costs as much as a new router) with no guarantee of a fix...
Any help would be appreciated.
Aug 20, 2021Guru - Experienced User
As a quick test, disable WPA security on the RBR. Turn OFF the RBS.
See if the Roku will connect with the open SSID. If so, try setting WPA and TPIK and see.
Then try WPA2 and AES.
Try factory resetting the Roku.
- hm69Aug 20, 2021Aspirant
Thank you FURRYe38 for your suggesstions.
FYI, the ROKU connects to the WIFI no problem - It is not able to connect to the internet.
In any case, I did try your suggestion, I turned off the RBS, disabled WPA and restarted the ROKU.- connects to the WIFI but still no internet.
Maybe this helps: this all started when I paused interenet on the Roku using the Orbi App. The Roku was not able to connect back to the internet when I "un-paused" it.
I think the Firmware update did mention something about an update to parental controls. So not sure if that has anything to do with the problem.
Thank you again, for your help.
I should also mention that I enabled Parental controls earlier in the month. Now I cant seem to disable it, but hopefully it will go away once my trial period expires.
- FURRYe38Aug 20, 2021Guru - Experienced User
Factory reset the RBR and setup from scratch. Don't reset the RBS, just leave them OFF.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQThis time, don't setup any access controls, Armor or Circle. Don't use the Orbi app to pause the Roku. Just set up the RBR plainly and see if the Roku will get internet services then...
