Gojulas
Dec 30, 2020Aspirant
Roku Netflix error tvq-pb-101 (3.1.19)
TLDR: after FiOS modem reboot can't stream Netflix and several other services on Roku.Need to also manually add https:// on some address in browser. Got a really perplexing issue here. It may in ...
- Dec 31, 2020
Turns out the Netflix error was a red herring. The real thing I should have focused on was the BRS_wanlan_conflict part.
I found an old post of yours where you recommended three different solutions. I choose number 2, which was to simply reset the Orbi, reboot the modem, and set up the Orbi as a new device. That solved it.... for now. If the GF reboots the modem again we will be back at the same point.
Your first recommendation was to configure the modem for transparent bridge mode. I need to look into that as a more perminant solution, but for now I'm able to stream again.
So... for anyone reading this in the future.... if you get this particular error don't factory reset your Roku, and don't remove and re-add Netflix. Not at least until you try looking up FURRYe38's solution for the BRS wanlan conflict.
Dec 30, 2020Guru - Experienced User
Contact Netflix and Disney for help and information since these are the only two apps failing and others are working.
Gojulas
Dec 31, 2020Aspirant
