Hbilliam
Feb 07, 2020Initiate
Roku spectrum tv app freezing
When trying to stream Spectrum TV app using my roku device, it freezes up after a few seconds. Spectrum TV says they are aware of the issue, roku tells me they are working with Specturm regarding th...
- Feb 10, 2020
I discovered that if you are using netgear ORBI and you disable orbi armor, the freeze up issue goes away.
jkandcrew
Feb 11, 2020Initiate
I reset my Orbi to factory settings then reinstalled it via the Orbi app just as I did the day I received it. It offered a free trial of Armor and I declined. Spectrum app has been working for almost an hour without freezing. Had to be the Armor security causing it. Just so happened the Spectrum app started freezing around the time the original "free trial" expired.
Joey
Feb 11, 2020Guru - Experienced User
Awesome. Thanks for letting us know.
Enjoy.
jkandcrew wrote:I reset my Orbi to factory settings then reinstalled it via the Orbi app just as I did the day I received it. It offered a free trial of Armor and I declined. Spectrum app has been working for almost an hour without freezing. Had to be the Armor security causing it. Just so happened the Spectrum app started freezing around the time the original "free trial" expired.
Joey
