WoundingFormula's avatar
Aug 12, 2020
Roku TV not auto connecting
I’m having issues with one of my TVs. I have a roku tv that with my previous netgear router, would stay connected and auto connect every time I powered it on/off. I purchased a new home and upgraded to an Orbi RBR50 with 1 satellite. The router is downstairs in my office, the satellite is directly above it upstairs. The issue is my roku tv upstairs, for whatever reason, I have to reconnect it to the network every time I power it on. Every time I turn on the TV, it says it fails to connect and I have to go into the TV settings, choose the network and connect. After that, everything works fine. Before I never had to do this. Anyone know any steps to resolve this issue so it just connects each time like before?
  • FURRYe38's avatar
    Make sure the TVs firmware is up to date.
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
  • If the TV has a soft reset feature, try that first. If that doesn't work, do a factory reset on the TV, which will clear any tables and info stuck in the TV.
