Kkrouse
Feb 07, 2022Aspirant
Roku tv won’t connect to my orbi39
My Roku tv will not find my Wi-Fi connect to orbi39
Feb 07, 2022Guru - Experienced User
Orbi39 would be the ssid, not the model.
What model orbi is it?
What firmware is on it?
What modem/gateway is the orbi connected to?
What error is the tv giving you or whats happening? Tough to know off "won't connect"
- KkrouseFeb 07, 2022AspirantRouter is a rbr40. Do you need a s/n. ? Modem is a arris tm1602. All my other tvs connect. Just not my Roku tv.
- KkrouseFeb 07, 2022AspirantWi-Fi won’t connect it just “spins”
- plemansFeb 07, 2022Guru - Experienced User
So its able to see the wifi on the screen but when you try to connect it won't?
have you checked the routers ssid/password for special characters or spaces?I've seen some devices have issues with that.
