Atticus0232
Dec 07, 2021Follower
Rookie trying to connect Nano M5 Stations- Help Needed
Hey all, I am new to this all and I think I have stumble as far as I can and now need some help from the experts. The home I purchased has 8 outside cameras. 4 of these are on a shop 60 feet ...
CrimpOn
Dec 07, 2021Guru - Experienced User
I think what the installation instructions fail to make clear is that the nanostation is supposed to be connected directly to a host computer with an ethernet cable. That is the reason to set a static IP address on the host computer. (with it not being connected to a network, the host computer cannot get an IP address using DHCP). Once the configuration process is completed, my guess is that the nanostation will be configured to use DHCP to get an IP address from the Orbi.
My advice is to look at a couple of the videos on like that go through the process of installing the nanostation m5.
