jaspolar
Apr 20, 2020Tutor
Roommmates security camera consuming 75% of our bandwidth. Orbi RBR50. Any way to vlan or limit it?
Hi all, We had been having issues at my house with slow network speeds. The Orbi was saying 443mb/s, but we were seeing fractions of that. After investigation with a hardline and device by device co...
Apr 20, 2020Guru - Experienced User
Whats the Mfr and model# of the ISP modem the RBR is connected too. The RBR50 is not a modem.
There is Traffic Meter however it only tracks the over all usage of the entire system and bandwidth. Not per device.
Only other item I might suggest would be a firelwall appliance device infront of the RBR and then set the Orbi system to AP mode. Use the firewall appliace to help regulate the bandwidth. Not sure which firewall appicance that would have these features. There are many.
You might ask this user to see if he might have any recommendations:
jaspolar
Apr 20, 2020Tutor
I'm relying on my roommates information, as it is configured in his room. I'll try to get more information for you. If there is a cable modem preceding it, we may have more options. I'll have to wait for the house meeting tonight.
