thedigester
Jan 20, 2025Aspirant
Roon cannot see endpoint as audio zone on Orbi RBK50 satellite
I use Roon to play music. It is an online digital media player that plays music stored on a network through audio zones ("endpoints") on the network. Problem - the kitchen audio endpoint appe...
thedigester
Jan 26, 2025Aspirant
OK I don't know if this is useful but this is the capture from the MS200 only:
Frame 3: 64 bytes on wire (512 bits), 64 bytes captured (512 bits) on interface en0, id 0
Section number: 1
Interface id: 0 (en0)
Encapsulation type: Ethernet (1)
Arrival Time: Jan 26, 2025 20:50:37.635696000 GMT
UTC Arrival Time: Jan 26, 2025 20:50:37.635696000 UTC
Epoch Arrival Time: 1737924637.635696000
[Time shift for this packet: 0.000000000 seconds]
[Time delta from previous captured frame: 23.356887000 seconds]
[Time delta from previous displayed frame: 23.356887000 seconds]
[Time since reference or first frame: 38.293597000 seconds]
Frame Number: 3
Frame Length: 64 bytes (512 bits)
Capture Length: 64 bytes (512 bits)
[Frame is marked: True]
[Frame is ignored: False]
[Protocols in frame: eth:ethertype:ip:igmp:igmp]
[Coloring Rule Name: Routing]
[Coloring Rule String: hsrp || eigrp || ospf || bgp || cdp || vrrp || carp || gvrp || igmp || ismp]
Ethernet II, Src: MeridianAudi_00:0e:84 (00:24:c5:00:0e:84), Dst: IPv4mcast_7f:ff:f9 (01:00:5e:7f:ff:f9)
Destination: IPv4mcast_7f:ff:f9 (01:00:5e:7f:ff:f9)
Source: MeridianAudi_00:0e:84 (00:24:c5:00:0e:84)
Type: IPv4 (0x0800)
[Stream index: 0]
Trailer: 0104020000000000000000000000
Frame check sequence: 0x00000000 [unverified]
[FCS Status: Unverified]
Internet Protocol Version 4, Src: 172.16.0.12, Dst: 239.255.255.249
0100 .... = Version: 4
.... 0110 = Header Length: 24 bytes (6)
Differentiated Services Field: 0x00 (DSCP: CS0, ECN: Not-ECT)
Total Length: 32
Identification: 0x899e (35230)
000. .... = Flags: 0x0
...0 0000 0000 0000 = Fragment Offset: 0
Time to Live: 1
Protocol: IGMP (2)
Header Checksum: 0xff23 [validation disabled]
[Header checksum status: Unverified]
Source Address: 172.16.0.12
Destination Address: 239.255.255.249
Options: (4 bytes), Router Alert
[Stream index: 0]
Internet Group Management Protocol
[IGMP Version: 2]
Type: Membership Report (0x16)
Max Resp Time: 0.0 sec (0x00)
Checksum: 0xfa05 [correct]
[Checksum Status: Good]
Multicast Address: 239.255.255.249
thedigester
I also asked Roon support about what subnet they saw. They replied:
Based on a recent diagnostic report, we see the MS200 reporting the following IP: 169.254.133.14
This IP scheme is used when a device cannot obtain an IP address from a DHCP server (e.g., a router or network server). When this happens, the device assigns itself an address in the 169.254.x.x range (with a subnet mask of 255.255.0.0) so it can communicate with other devices on the same local network without requiring manual configuration.
I'll try setting the IP address within the MS200 as static to see if that makes a difference.
Thanks again for your help.
