bryanhughes
Nov 14, 2021Aspirant
Root privileges on VPN configuration?
I Just installed the VPN client.conf with Tunnelblick and it warns me: One or more VPN configurations that are being installed include programs which will run as root when you connect to a VPN. T...
CrimpOn
Nov 14, 2021Guru - Experienced User
This sounds like a question for Tunnelblick, which is not part of the process recommended by Netgear.
I do not see any 'applications' in the client.conf file Orbi produces for MacOS.
Could perhaps there be a different OpenVPN configuration file that Tunnelblick is complaining about?
bryanhughes
Nov 15, 2021Aspirant
Thanks for replying. This is the only VPN configuration on my Macbook. Netgear specifically says to use Tunnelblick. I looked at the conf as well and do not see any specified applications. The warning from Tunnelblick does specifically say that this is not from Tunnelblick.
I am frustrated that Netgear only provides 90 days of support, which is lame considering I spent several hundred dollars on this setup and should at least deserve a limited number of support requests. At least Apple does this.
- CrimpOnNov 15, 2021Guru - Experienced User
You are absolutely correct. I skimmed over the MacOS directions and did not recognize Tunnelblick.
No idea what that warning message was about. There is nothing in the client.conf file that should be a concern.
I searched for Tunnelblick and root and got results talking about how Tunnelblick itself requires root priviledges.
Not much help. Sorry.
