RamaSubbu_SK
May 11, 2022Initiate
Router Admin portal says update files for "Orbi Satellite RBW30"
How fix the firmware update failure?
CrimpOn
May 11, 2022Guru - Experienced User
The first choice is, "if it ain't broke, don't fix it." i.e. If the WiFi system is not causing any problems, leave it alone.
The second choice is a manual firmware update, where you:
- Download the RBW30 firmware from the support web site.
- Unpack the zip file to extract the RBW30 image file.
- Connect a web browser directly to the RBW30 satellite web page using the satellite's IP address
- Select the Firmware Update item on the menu.
- RamaSubbu_SKMay 11, 2022Initiate
The support website shows the same version only : Orbi RBW30 | WiFi System | NETGEAR Support
- CrimpOnMay 11, 2022Guru - Experienced User
Absolutely correct. I failed to check the web site. Thanks!
