RamaSubbu_SK
May 11, 2022Initiate
Router Admin portal says update files for "Orbi Satellite RBW30"
How fix the firmware update failure?
RamaSubbu_SK
The support website shows the same version only : Orbi RBW30 | WiFi System | NETGEAR Support
CrimpOn
May 11, 2022Guru - Experienced User
Absolutely correct. I failed to check the web site. Thanks!
