Brinch
Apr 20, 2020Tutor
Router admin screen doesn't show same info as Orbi app
When I log into my Orbi router through a website, it says that there are no satellites connected and only 1 connected device, even though we have approximately 30 devices that are connected to the wi...
- Apr 20, 2020
It is on the "Top Support Articles" on that page, go to https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16 to download the zip files. Extract the ZIP files, install the .img file on the satellites first, then on the router.
Brinch
Apr 20, 2020Tutor
Size of home is about 2500 sq ft.
One satellite is one floor above router.
One satellite is about 15 yards away.
Using Chrome
Apr 20, 2020Guru - Experienced User
What happens if you turn OFF the one RBS thats shows connected, Reboot the RBR and see if the other RBS appears?
Is daisy chain enabled? If it is, disable it and reboot the RBR and turn on the RBS. Don't revet back. It's not a FW issue.
Becareful reverting FW,
Brinch wrote:Size of home is about 2500 sq ft.
Using Chrome
