Brinch
Apr 20, 2020Tutor
Router admin screen doesn't show same info as Orbi app
When I log into my Orbi router through a website, it says that there are no satellites connected and only 1 connected device, even though we have approximately 30 devices that are connected to the wi...
- Apr 20, 2020
It is on the "Top Support Articles" on that page, go to https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16 to download the zip files. Extract the ZIP files, install the .img file on the satellites first, then on the router.
Retired_Member
Apr 20, 2020
Brinch wrote:How do I revert back?
go to download area....enter in your model number.....look for available firmwares
Brinch
Apr 20, 2020Tutor
Which firmware is best to revert to? Any favorites out there?
- Retired_MemberApr 20, 2020
Brinch wrote:Which firmware is best to revert to? Any favorites out there?
I've been on V2.3.5.30 since October 2019 with no problems
- FURRYe38Apr 20, 2020Guru - Experienced User
I've been on v2.5.1.8 since December 2019.;..
v2.5.1.8 has many folks with tons of problems, like the one in this OP. stop being blind
