mrmaz25
Jun 15, 2018Aspirant
Router and Orbi setup
I have recently purchased a Nighthawk X10 AD7200 smart wifi router and the Arlo Pro 2 (3) camera security system. I have all Apple computers, phones, and tablets, including the time machine backup sy...
- Jun 15, 2018
The x10 should cover your home and some out side.
Any cable modem will connect to any of the NG routers. Orbi or other router model.
The CBK/R modems already have a bulit in cable modem. So this model you may not need.
If your looking for a more full range and more coverage, then the RBK/R 40 and 50 series models would be something you would want to look into. These don't have a built in cable modem and are just the router and satellites.
mrmaz25
I have the Samsung SmarThings system hooked up to all of my light switches and other enabled smart home devices. I don't know if this is pertinent information but I thought I would include it as a reply. Thanks
