mrmaz25's avatar
mrmaz25
Router and Orbi setup
I have recently purchased a Nighthawk X10 AD7200 smart wifi router and the Arlo Pro 2 (3) camera security system. I have all Apple computers, phones, and tablets, including the time machine backup sy...
  • FURRYe38's avatar
    The x10 should cover your home and some out side.
    Any cable modem will connect to any of the NG routers. Orbi or other router model.
    The CBK/R modems already have a bulit in cable modem. So this model you may not need.
    If your looking for a more full range and more coverage, then the RBK/R 40 and 50 series models would be something you would want to look into. These don't have a built in cable modem and are just the router and satellites.
