richards10
Nov 10, 2018Aspirant
Router and Orbi setup
I have a modem/router provided by my ISP. I bought the orbi in order to provide coverage to parts of my house that have poor Wi-Fi. I'm not sure how to set the orbi up to work in this manner. I hope t...
Nov 11, 2018Guru - Experienced User
Please post this here in the main Orbi forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
This forum is for the cable Orbi system
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
