RavetheDave
Mar 27, 2020Aspirant
Router and Satellite help
Hi Hope someone can help I have had the RBR50 for a couple years now with one satellite and they worked perfectly until I updated the firmware last week, since then connections have dropped everywh...
Retired_Member
Mar 27, 2020revert your FW and stop performing updates....or get ready for the dozens of questions to follow
- RavetheDaveMar 27, 2020AspirantRevert fw to which one? Does it update automatically then?
- Retired_MemberMar 27, 2020
RavetheDave wrote:
Revert fw to which one? Does it update automatically then?how did the update happen? Did you do it or did you wake up one morning there it was?
- RavetheDaveMar 27, 2020AspirantI did the update via the app but then I rolled it back manually
