NandoCalrissian
Feb 02, 2019Aspirant
Router blocks Netflix streaming, Sonos speakers in spotify and Hive
Hi all, i recently purchased an RBK40 and DM200 to use with my vodafone broadband. I use the DM200 in bridge mode and the RBR40 as the router. However, when i use this set up i cannot stream Neflix o...
Chuck_M
Feb 02, 2019Mentor
Ensuring you really have your DM200 it in bridge mode: Please read this and double check:
https://kb.netgear.com/30773/How-to-set-DM200-into-bridge-modem-only-mode
What is the RBK40's IP address? Do other devices get issued private IP addresses by the RBK40? (192.168.1.X?)
Is your satellite installed? What is it's issued IP address?
Are you using any special DNS or defaulting to your ISP?
Can you open a command prompt and do a tracert to netgear.com and post those results here?
I presume you have current firmware loaded in both router and satellite.. . what versions are they?
NandoCalrissian
Hi chuck, thank you for getting back to me.
DM200 definitely in bridge mode.
RBR40 IP us 192.168.1.1 and other devices get private IPs
Sattelite is installed with IP 192.168.1.4
i am using my ISPs DNS
Tracert below. All firmware is up to date.
any ideas/ i have read a lot about DM200 bridge mode causing issues but do not know how to resolve them.
