NandoCalrissian
Feb 02, 2019Aspirant
Router blocks Netflix streaming, Sonos speakers in spotify and Hive
Hi all, i recently purchased an RBK40 and DM200 to use with my vodafone broadband. I use the DM200 in bridge mode and the RBR40 as the router. However, when i use this set up i cannot stream Neflix o...
JoeCymru
Feb 02, 2019Virtuoso
Try it with your Sonos speakers disabled. If that proves to be the issue, and your speakers were wired, try it with them wireless.
ekhalil
Feb 02, 2019Master
+1
Since you'e using Sonosnet I guess that you have wired speakers. How many wired Sonos speakers do you have?
NandoCalrissian can you please copy and paste the tracert results as we can't see the attached picture until it's approved by a moderator :)
- NandoCalrissianFeb 02, 2019Aspirant
HI Joe and Ekhalil
text below. thanks. i will wire a speaker in but it worked with the old modem plugged back in with the orbi as an AP so there is something going on with the the DM200 or Orbi when in router mode.
C:\>tracert netgear.com
Tracing route to netgear.com [34.208.150.59]
over a maximum of 30 hops:1 2 ms 3 ms 3 ms 192.168.1.1
2 10 ms 9 ms 8 ms
3 10 ms 10 ms 11 ms 63.130.104.194
4 10 ms 10 ms 9 ms ae13-600-xcr1.ltw.cw.net [195.2.23.77]
5 140 ms 140 ms 141 ms ae5-xcr1.slo.cw.net [195.2.24.33]
6 78 ms 79 ms 78 ms ae2-xcr1.nyh.cw.net [195.2.28.169]
7 144 ms 143 ms 143 ms xe-7-0-1-xcr1.pal.cw.net [195.2.25.133]
8 143 ms 142 ms 142 ms 52.95.216.76
9 144 ms 145 ms 144 ms 54.240.243.52
10 142 ms 142 ms 143 ms 54.240.243.61
11 * * * Request timed out.
12 163 ms 163 ms 161 ms 52.93.128.26
13 160 ms 160 ms 160 ms 54.239.44.1
14 * * * Request timed out.
15 178 ms 173 ms 163 ms 52.93.14.188
16 159 ms 159 ms 157 ms 52.93.14.179
17 174 ms 199 ms 167 ms 52.93.14.178
18 160 ms 159 ms 165 ms 52.93.14.201
19 160 ms 160 ms 160 ms 52.93.13.71
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.Trace complete.
- Chuck_MFeb 02, 2019Mentor
I think as well that your issue is with or before the DM200 and not your internal network. All else appears to be correct -- especially since it worked with a different router.
Have you contacted your ISP to see if your system is operating at 100% from their perspective? It could be some improper settings on their end that are causing issues. You said their hardware dropped frequently before you swapped equipment.
- ekhalilFeb 02, 2019Master
NandoCalrissian wrote:
......... i will wire a speaker in but it worked with the old modem plugged back in with the orbi as an AP so there is something going on with the the DM200 or Orbi when in router mode.
So you currently have no wired speakers?
PS. Please remove the IP address in the second line in the tracert printout above as this is your public IP address, if you can edit the post.
NandoCalrissian What type of wired devices do you have connected to Orbi? Can you also confirm if any of the Sonos speakers are wired?
