sw2125
Jul 18, 2018Follower
Router bricked after reboot
My orbi router seems to have bricked after powering down for a reboot. There is no power light when the network cables connect, nor led lights that come on when powering up. the only light ...
Jul 19, 2018Guru - Experienced User
Check a different power out let.
Check the power adapter tip for voltage and amp. Should be same as listed on the power adapter brick sticker.
Press in the reset button on the back of the router for 15 seconds. The top led should turn on Amber or Yellowish. If it does, release the button and led should start blinking WHITE the pulsate WHITE.
If this fails, you'll need to talk to NG for an RMA...
