Daveystas
Feb 01, 2020Follower
Router capacity question
I have an orbi rbr20 with two satelites in my home.....I feel like my internet speed has slowed down since I installed a wifi security alarm and have two kids with tons of devices using the bandwith....
Feb 01, 2020Guru - Experienced User
Seen some having problems with 20 series Orbis on 1Gb ISP services. Seen some that they work fine. I know the 50 series seem to work better. You can use Orbi RBSs on other series Orbi. The RBRs don't work at all as RBS.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
