tsmith1047
Dec 22, 2022Follower
Router.com Login Issue
I am having a hell of a time accessing my https://routerlogin.net account. It says user name (to use admin) and password to use (password) I have used those, I have tried my login for the netgear sit...
Dec 22, 2022Guru - Experienced User
the defaults are
Login: admin
password: password
However, it requires you to change it when you first set it up. so if you've already set it up, it won't be those.
You can try password recovery (if you set it up, it still asks the questions, even if you didn't)
If you setup insight, you can try access it that route.
If none, of those work, then you'd need to factory reset to get back in.
