Yummy571
Apr 29, 2020Tutor
Router does NOT detect internet
RBR20 router shows red dot next to it lately. It does not detect internet. I have wifi fro Orbi network yet some sites are not accessible. How can I have wifi and yet the router is NOT detecting inte...
Apr 29, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance?
Power OFF the ISP modem and RBR for 30 seconds, then power ON the Modem first, then the RBR.
- Yummy571Apr 30, 2020Tutor
Hi thanks for replying. There was NEVER a change from internet provider side. Things started going bad when I connected the outdoor satellite. All works well but some sites are not accessible and the App shows that the router is not connected to internet! All worked perfectly before. Thanks once again for your time.
- FURRYe38Apr 30, 2020Guru - Experienced User
Yummy571 wrote:Hi thanks for replying. There was NEVER a change from internet provider side. Things started going bad when I connected the outdoor satellite. All works well but some sites are not accessible and the App shows that the router is not connected to internet! All worked perfectly before. Thanks once again for your time.
