Yummy571
Apr 29, 2020Tutor
Router does NOT detect internet
RBR20 router shows red dot next to it lately. It does not detect internet. I have wifi fro Orbi network yet some sites are not accessible. How can I have wifi and yet the router is NOT detecting inte...
Retired_Member
Apr 29, 2020
Yummy571 wrote:RBR20 router shows red dot next to it lately. It does not detect internet. I have wifi fro Orbi network yet some sites are not accessible. How can I have wifi and yet the router is NOT detecting internet?! I rebooted, factory reset and all that is possible. Can anyone help please?
Has your orbi ever worked correctly?
Yummy571
Apr 30, 2020Tutor
Hi thanks for replying. Yes the router worked perfectly for two months. Then I tried comnnecting an outdoor satellite and it works but since then the router says its offline! However there still is wifi, however i noticed some secure sites seem inaccessible. Also the app says it doe NOT detect internet!!! Very strange indeed. (see screenshot). Many thanks, keep safe my friend.
- Retired_MemberApr 30, 2020
Yummy571 wrote:Hi thanks for replying. Yes the router worked perfectly for two months. Then I tried comnnecting an outdoor satellite and it works but since then the router says its offline! However there still is wifi, however i noticed some secure sites seem inaccessible. Also the app says it doe NOT detect internet!!! Very strange indeed. (see screenshot). Many thanks, keep safe my friend.
forget the app for awhile.
can you hit the internet from a pc? what type of modem do you have?
- Yummy571Apr 30, 2020Tutor
Hi I got internet and managed to get into orbi.com and can see all my configutrations...
Yummy571 wrote:Hi I got internet and managed to get into orbi.com and can see all my configutrations...
good....be careful while there. do not make any changes to the settings unless you know the consequences
