rchorowitz
Feb 26, 2019Aspirant
Router Dropping Internet Connection Constantly
It seems I am one of many who has an unstable Orbi.
The GUI internet status changes from good to disconnected.
It happens constantly. I added another RDS50 because I thought it was a dis...
CrimpOn
Feb 26, 2019Guru - Experienced User
It happens constantly. I added another RDS50 because I thought it was a distance problem, without resolution.
Can you please describe more about "constantly"? i.e. Is it every 10 minutes? every hour? once a day? Do you see anything in the Orbi log file that corresponds to the times when it disconnects?
- rchorowitzFeb 26, 2019Aspirant
There is nothing in the Orbi log....
On the mobile phones iPhone X/7SE/Galaxy browsing is almost impossible. Pages almost never completely load.
On the Fire TV, it is several times withing a 30 minute period.
- mrfrancFeb 26, 2019Apprentice
What about the FVS336Gv3 logs? Are they enable?
- CrimpOnFeb 26, 2019Guru - Experienced User
Could you please list the IP addresses for the Arris port, both sides of the NG router, and the Orbi's?
"GUI" refers to (a) the Orbi web interface Home Page, or (b) a smartphone app?
Those hard wired devices that "have no problem", are they connected to the NG ProSafe or to the Orbi?
With no neighbors, a WiFi scan should have only the Orbi SSID's. (I use WiFi Analyzer from the Google Play store - it's free.) Looking at the Time Graph, the WiFi signal never "drops out", correct?
- FURRYe38Feb 27, 2019Guru - Experienced User
Connect the Orbi in AP mode directly to the ISP modem in router mode. Test to see if devices get correct internet access.
