WarriorStrong99
Dec 01, 2021Aspirant
Router Ethernet Much Slower than Modem
Router Much Slower than Modem Some quick information: - 500mbps Internet plan - ROUTER: Orbi RBR20 with 2 satellites near each other running at 50% transmission power (quite a small house). - MO...
Dec 01, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC connected directly to the back of the RBR and a web browser. I would also not enable Armor, Access Controls, Circle or Traffic Meter after completing the setup wizard.
