lcalcari
Oct 28, 2020Aspirant
Router Firmware update on app or chrome
I have had nothing but problems when using the Orbi RBR50 with three satelites. The satelites will consistently drop out and have to be reset in order to come back online (weekly). I have yet to be a...
- Oct 30, 2020
Please mark your thread as solved so other will know.
Enjoy. :smileywink:
CrimpOn
Oct 28, 2020Guru - Experienced User
lcalcari wrote:I have had nothing but problems when using the Orbi RBR50 with three satelites. The satelites will consistently drop out and have to be reset in order to come back online (weekly). I have yet to be able to access the orbilogin.com since the original set up on chrome, safari, firefox. I have followed all of the cache and browser history tips with nothing working. The Orbi app is a whole other issue. I am connected to my local wifi via the Orbi router and the app has to connect via the anywhere option since it cannot find my network (the one I am using to access the app). I need to update firmware, but neither the app or the orbilogin are options. How else can this work? These are too expensive to have all the issues.
When the Orbi was set up, was a lot of effort put into "customizing" the configuration? Things like assigning IP addresses to specific devices, defining device "names" and "types" in the Attached Devices display?
If not, what about performing a Factory Refresh and setting the system up from scratch using a web browser?
lcalcari
Oct 29, 2020Aspirant
I did not do any customization to the router during installation other than define a guest network. I am trying to avoid the factory reset if possible, but will check out the video and if I cannot find another way go this route. Thank you
