dmoyers
Apr 25, 2018Star
Router Firmware Version V2.1.4.10 Brought My LAN to Crawl
I just updated to above stated firmware version. It brought my wired and wireless connection down to a crawl. It's averaging 1.5Mbps on a wired connection and worse on wireless. This morning I author...
dmoyers
Apr 26, 2018Star
Sorry, not sure what version of the firmware was on it before today. I can say that I check it at least once per month for updates and install same. I'm thinking it had to be current. I have no issue starting from scratch.
Apr 26, 2018Guru - Experienced User
Reset both router and satellite and and set up from scratch. Set up the router first, the add the satellite.
Let us now how it goes.
- dmoyersApr 26, 2018Star
Reset to factory defaults and no difference in speeds: 498ms ping, 368Mbps down and 107Mbps up
- tsigApr 26, 2018Luminary
which is it?
first you say Hook straight to the modem and get full speed around 20Mbps up and 1.5Mbps down, then after a reset you get
sounds like a reset gave you more speed...
So sorry. Amazing what a "dot" can do. Edit: 3.68 Mbps down
