dmoyers
Apr 25, 2018Star
Router Firmware Version V2.1.4.10 Brought My LAN to Crawl
I just updated to above stated firmware version. It brought my wired and wireless connection down to a crawl. It's averaging 1.5Mbps on a wired connection and worse on wireless. This morning I author...
dmoyers
Apr 30, 2018Star
Forget about all the rest of local area network. I have a Motorola SB6183 modem wired to Netgear Orbi RBR50. I isolated everything else and have butt-slow speeds wired and wireless connected this way. I can hook straight to the modem and full speed consistently. Everthing was fine until I intalled the latest firmware. I reset back to factory default settings and reinstalled latest firmware and still slow. I have changed cables throughout and no change. I've hooked two different pc's straight to the router with same results. It has to be the router/switch. I have seen brief periods over the past two days where it reched normal speeds. This system is less than a year old and lives in a good enviroment. More than happy with it up until this point. But with that being said--I can't live this as it is and will be looking at other options.
Apr 30, 2018Guru - Experienced User
Only other idea would be to downgrade FW, back to v2.1.3.4 or last known working FW.
If this still fails, I would made contact with DarrenM and see what he recommends.
- dmoyersApr 30, 2018Star
Thanks so much. I'm just frustrated at this point. I'm not a network specialist but can get around better than most.
