Bkirley
Oct 24, 2020Aspirant
Router flashing white. No connection via ethernet
Yesterday the Orbi router lost power and never came back online. It is flashing white light on top. Modem works fine - confirmed with old router. Tried to connect to Orbi via Ethernet as I’ve re...
Oct 25, 2020Guru - Experienced User
Tried to connect to Orbi via Ethernet as I’ve read updating firmware might help and there is no connection. I am not sure how to move forward if I can’t even get a connection via Ethernet. Any ideas?
- BkirleyOct 25, 2020AspirantModem: Ubee; DDW36C
Not sure what firmware is loaded because I have no way to access the router. The app doesn’t find it and I have no internet connection when plugged into the router via Ethernet.- FURRYe38Oct 25, 2020Guru - Experienced User
Your modem already has a build in wifi router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option #3 first...
