Bkirley
Oct 24, 2020Aspirant
Router flashing white. No connection via ethernet
Yesterday the Orbi router lost power and never came back online. It is flashing white light on top. Modem works fine - confirmed with old router. Tried to connect to Orbi via Ethernet as I’ve re...
Bkirley
Oct 25, 2020Aspirant
Modem: Ubee; DDW36C
Not sure what firmware is loaded because I have no way to access the router. The app doesn’t find it and I have no internet connection when plugged into the router via Ethernet.
Oct 25, 2020Guru - Experienced User
Your modem already has a build in wifi router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #3 first...
