DodgerJeff
Dec 09, 2017Aspirant
Router IP changed from 192.XXX to 10.xxx
My new Orbi has changed from 192.168.1.1 to 10.0.1.1 Now I cannot connect to Orbi at all. Tried typing in 10.0.1.1 and also I see that Mac Internet setting say IPv4 address 10.0.1.46 and that doesn...
MrX911
Dec 10, 2017Apprentice
DodgerJeff wrote:My new Orbi has changed from 192.168.1.1 to 10.0.1.1
Now I cannot connect to Orbi at all. Tried typing in 10.0.1.1 and also I see that Mac Internet setting say IPv4 address 10.0.1.46 and that doesn't work either.
Internet speed has gone from 116Mb/s to 2Mb/s
Orbilogin.com or .net doesn't work either.
Have you 10. is usually when it is in router mode. Have you changed to brdige/acces point mode?
Also make sure you are on the same network to access orbi login. for example if you are a wired logi staight to anything other than your Orbi you wont be able to acces it, so change to wifi connection on orbi OR wired to orbi.
