DodgerJeff
Dec 09, 2017Aspirant
Router IP changed from 192.XXX to 10.xxx
My new Orbi has changed from 192.168.1.1 to 10.0.1.1 Now I cannot connect to Orbi at all. Tried typing in 10.0.1.1 and also I see that Mac Internet setting say IPv4 address 10.0.1.46 and that doesn...
DodgerJeff
Dec 10, 2017Aspirant
I have a Netgear CM500 that is only a cable modem. That is the only thing connected to my Orbi.
st_shaw
Dec 10, 2017Master
That modem has a fixed IP address of 192.168.100.1 for adminitrative access.
What did you enter on the Orbi LAN settings for your LAN address and subnet mask? You should enter 192.168.1.1/255.255.255.0.
If you were to use a different subnet mask (e.g. 255.255.0.0) Orbi would exhibit this behavior.
