jkyorbi
Jan 21, 2019Follower
Router is getting great speed but not to device - Fios 1gb and Orbi RBR50 w satellites
Fios 1gb, Orbi router speed test results around 800mb up and down which I’m happy with. But to devices I get speed range of 40-120mb. How can I improve speed to devices from Orbi system?
Jan 21, 2019Guru - Experienced User
What FW is currently loaded?
What devices do you have?
Not all wireless devices are able or support speeds much over 400-500Mb. Depends on how Mfrs designed them and what actual thruput speeds they can do. Check with the Mfr of the devices to see what is officially supported. Connection rates differ from thruput rates.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
