mgandolfo
May 13, 2019Aspirant
Router login issues
I'm having trouble with logging into my Orbi router using the standard admin credentials that are on the unit. Any help trouble shooting this problem would be appreciated.
Thanks,
May 13, 2019Guru - Experienced User
Default log in is admin and password. After that if you set it up for something different, you'll need to factory reset the RBR and walk thru the setup wizard and be sure to write down all important information for safe keeping later on.
