mgandolfo
May 13, 2019Aspirant
Router login issues
I'm having trouble with logging into my Orbi router using the standard admin credentials that are on the unit. Any help trouble shooting this problem would be appreciated.
Thanks,
mgandolfo
May 14, 2019Aspirant
I am using the default credentials to login to my router and it fails. My attempts are all from a wireless access point, so does it matter if I am wireless or hard wired into the router when logging in?
May 14, 2019Guru - Experienced User
Try a factory reset on the RBR and this time walk thru the setup wizard with a wired PC and web broswer.
