MartijnOrbi
Mar 03, 2019Guide
Router loses 2.4ghz network within 24 hours
Since a year I'm the owner of the ORBI RBK50 system, consisting of an RBR50 router and a satellite (RBS50). This setup has always worked perfectly fine, however since a couple of weeks I need to rest...
ekhalil
Mar 03, 2019Master
MartijnOrbi wrote:
........... Lately the network becomes unavailable, both wired as well as wireless. The Router doesn't give any visual indication, it is just unavailable. The sattellite has a flashing purple ring at the top.
To me it looks that Orbi is -for some reason- loosing the IP address assigned to it by the modem.
When the issue happens, if you don't restart the router but only pull out the WAN cable coming from the modem and plug it again, will this also fix the issue? If yes then we need to look at the modem and the interface towards it.
Also the subject of this post mentions the 2.4 GHz network, but I don't see the relation of this with your description of the issue??
- MartijnOrbiMar 03, 2019Guide
ekhalil That is an excellent suggestion, I have just updated the firmware, and hope that did the trick. However if that doesn't work I will definitely try the WAN cable. Thanks!
With regards to the title: You are totally right, that doesn't make sense at all, that should be something like: Cannot access network within 24 hours after reboot.
- MartijnOrbiMar 04, 2019GuideI did the following:
- Firmware upgrade
=> still the same issues
- unplug/plug WAN cable
=> no changes, router still not reachable (no SSID available for wireless and not able to recognize a network of some sorts when linked directly through UTP.
- changed channels for 2.4Ghz and 5Ghz (haven’t tried all yet).
=> same behavior, after a couple of hours the network is ‘gone’ (no SSID and no network through UTP).
When I reset my router by turning off/on or unplug the cable, sometimes no SSID signal can be found at all (I need to repeat multiple times).
With regards to the questions raised earlier:
Size house: 120 sqm (but irrelevant, because only partly covered)
Distance between router and satellite: <6m (almost directly above each other and backhaul signal is always good)
IP modem: ZTE h368n
Any other ideas?
I get the slight feeling that something is wrong with my router and I might need to make a warranty claim.- FURRYe38Mar 04, 2019Guru - Experienced User
6m is too close, try 10m.
If you factory reset the Orbi router, when the top LED pulses WHITE, look at any mobile wifi device, do you see the default setup SSID listed at all? If not, possible HW failure with the Orbi.
Your ISP modem has a built in router already. Is the Wifi disabled on the Modem?
Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Firmware upgrade
IP modem: ZTE h368n
Any other ideas?
