wlbrocu
Jun 24, 2021Aspirant
Router Not able to find the ORBI193 network
My router stopped connecting yesterday. I restarted the modem and then the router several times. The app cycles through the set up process, but when it asks to join the network, it comes back with ...
- Jun 24, 2021
I logged onto orbilogin.com and rebooted my router from there. It worked! Thanks for your help.
Jun 24, 2021Guru - Experienced User
Factory reset the RBR and setup the RBR from scratch using a wire connected Pc and a web browser...
- wlbrocuJun 24, 2021Aspirant
Thank you for this suggestion. I will try it next.
I had the entire mesh set up working since September 2020. Yesterday, the router went out and I haven't been able to get it back. Fortunately, the Anywhere Access on the Orbi app is giving my home Internet as the ISP modem does not have a built in router. I've tried resetting the router several times, but it hasn't worked. The only thing I can think of is that the firmware isn't up to date. I'm trying to access my Orbi account on my pc since the Orbi app just keeps spinning trying to get connection.
- FURRYe38Jun 25, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
Enjoy.
