it4her
Sep 30, 2019Aspirant
router not found
FIOS environment ALL MAC shop (laptops, desktop, mobile devices) unable to connect router. I am able to see the broadcast,I'm able to login however unable to connect with any device. It hasn't allowe...
it4her
Firmware FIOS Quantum G1100 01.04.00.10-FTR
Sep 30, 2019Guru - Experienced User
This has got a buiilt in router already.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
it4her wrote:Firmware FIOS Quantum G1100 01.04.00.10-FTR
