Jershar
Jul 22, 2020Follower
Router offline
Have Orbi RBR20. It shows that the router is offline. I have 2 satellites that show they are connected. My WiFi works for most apps, but will not stream amazon video. I have rebooted, reset, called my internet provider( a local company- fiber). All to no avail. A picture of my network is attached. Please don’t get too technical....limited knowledge in this area. Any idea what else I can try?
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-appThere are some known problems with the Orbi app.
Good Luck.- dloo2002AspirantI have the same problem router off, satellites green.
What did you do to fix ?- FURRYe38Guru - Experienced User
IF this is with the Orbi app,
Good Luck.
