markgriffith11
Jan 21, 2020Follower
Router on 2nd Floor, Satellite on 1st Floor, Extending to Basement?
***Pls note- Im pretty sure my Orbi is the RBK50 which did note show up as an option*** My Orbi Router is on the 2nd floor of my house. The satellite is on the first floor. I also have a media ro...
ND40oz
Jan 22, 2020Aspirant
Make sure you have daisy-chaining enabled and it will work fine. You'll want to place the new satellite somewhere in the basement that still has good signal to the satellite on the first floor which likely won't be that close to your Roku and Xbox if they don't have good signal from the one on the 1st floor now. But then they'll get a much better wireless connection to the new satellite in the basement then they were getting from the one on the 1st floor so you shouldn't have to worry about wiring them up through ethernet.
